Just getting this TV set up with a soundbar connected (via optical). I can connect bluetooth headphones no problem (in this case MDRXB950BT, which work fine with firestick on another TV):
However, there's no sound. The TV sound continues to play from whatever source is selected - the options are TV Speakers and Audio System. How do I actually get it to output to bluetooth?
Reboot Android TV, keep pressed Power/OFF on Remote...
Thanks for the reply - I had already done a restart via the menu, but I did another with the remote - with the same result - I get popups when the headphones are connected and disconnected but no sound.
Checking again with sound on TV speakers, I can tell the TV sound profile changes when BT is connected - sounds like it's bypassing the sound settings like surround etc - but it still comes out from the speaker and nothing over Bluetooth.
Is the expected behaviour to switch to BT output when connected and turn off the TV speakers? If so, it's definitely not happening...
https://helpguide.sony.net/tv/haep2/v1/en/08-05_09.html
To output sound from both the headphones/Bluetooth audio device and TV speakers
The TV cannot output sound from both the headphones or Bluetooth audio device and the TV speakers at the same time.
On my old Sony Bravia the speakers worked normally with the headset (Amplicomms) Bluetooth headset in and working. It doesn’t on my 80JS.
