Hi.
Cheers.
Hi @SatB_81
I have been known to simply buy a "plank" to fit the TV Stand and with a bit of paint or varnish blend it in nicely.
Can you turn the legs 180 degrees, or swap them one for the other, so they splay inwards?
Cheers. I will have a look and see if that works.
I don't think they can be adjusted. Sony created an article for TVs that can have there stand adjusted here. So you can try these suggestions see if it works for you.
