Can you please help me with my sony kdx 49 xg 8096 is conected to wi fi but you tube constantly says try again but I can watch Netflix without problems and the network is ok conected other devices work perfectly. With factory reset problem is solving but its not a solution. Restarted router and so on but stil masage is wifi is conected but no internet.
Check the date & time on the TV is set correctly, if not enable "Automatic time & date" option.
If the date/time is incorrectly set it manifests itself as no internet but Netflix still works.
