- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi my Android tv is blank,on the screen but sound is playing...
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi again.. I switch on the Tv and there’s vertical lines all over the screen after an hour or so it fixes and shows like new if I switch it off and open it the next day it does the same again then shows again. Could it be the t cord board?? Or is it the panel if it’s the panel I don’t think it’s worth fixing due to high costs. I’m a big time Sony fan but disappointed at the moment as I have heard it’s a common problem on Sony’s smart TVs with the same problem as mine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
Have you tried a factory reset which should resolve the issue? You can see more details on how to perform this here.
Best wishes,
Sean
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Sean. Yes I did it but no luck.Could it be the t con board that’s causing it ?
Thanks for replying
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi again,
Sorry to hear that this did not resolve the issue for you.
I would recommend getting in touch with the support team here who will be able to advise further.
Best wishes,
Sean
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Στάλθηκε από το Ταχυδρομείο Yahoo για iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
