I have been given this television and have tried connecting an Amazon Firestick to it with no success. There is only one HDMI socket on the back of the tv , Whem I scroll through the settings I can`t see an HDMI tab to click on !, does this mean that the socket is not connected or is there something I am missing ? There are such things as AV1, AV2, AV3, External Feed etc that can be highlighted. I am far from an electronics wizard but understand basic instructions in my senior years !
Also the remote control unit does not operate the volume on the tv but can be done on the tv itself.
Any information would be appreciated.
Hi Alladin,
I found in the manual that the HDMI port is represented in the input list by AV4.
The TV seems to be a bit on the older side, this means that the HDCP version supported by the HDMI port on it could be out dated, causing incompatibility with newer HDMI devices.
I hope that helps
Win_88
