My KDL-75W850C won't even get through the first setup. I have tried everything said in this forum about restarting the tv. Nothing changes. Once the network connection is established, the setup loops back to language selection! The network connection remains but the setup goes back to the "Welcome" at the language selection.
This is weird. What's the problem?
Hi there
Can you try going through the setup again, but this time do NOT connect the TV to the network. You can always connect the TV onto the network at a later stage - assuming you get passed the language screen. I recall this aproach has worked before on someone else.
However your model is not an EU model TV? Are you based in the US?
Thanks for the correction - didnt know they sold the 75" of this model in EU
Yes, unfortunately if all else fails - its a 'mainboard' replacement.
