- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
kdl-50w805c
Hi all. I cannot get this tv to play anthing smooth. The only thing that works is tv broadcast.
Kodi from tv. Juddery
Kodi from pc. Juddery
Xbox 360. Juddery
Xbox one. Juddery
Ps3. juddery
Ps4. Juddery.
I think you get the idea. It seens not matter what settings i change nothing helps. Turn all the motion flow stuff of and its unusable.
Finely tune every last setting on the dam thing and i still fet a judder every 10 seconds or so.
Ive had it with this tv.
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @rodensony, welcome to the Community.
Can you confirm you have the latest firmware installed?
It would also help to know how you are connecting your external devices, ie. HDMI etc.
Also check whether these playback problems only occur when there are black panels above and below the main image on the screen (such as you see in 16:9 aspect) as this is an issue we have seen reported here in the past.
Finally, have a search through the Community threads, as you may find a variety of related problems and solutions there.
Best wishes
Mick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, thanks for the reply.
Sorry about the original message did it on my phone.
Yes latest firmware, does not matter if its 16:9 fullscreen or whatever.
I first noticed it while gaming, all of a sudden its like frame drops and judders, mainly when moving from lef to right with fast motion.
everything connecting by hdmi
I have tried changing every setting on my consoles, every setting on the tv. every setting on kodi wether run from the tv or pc.
Only way i can descride it is like the tv is struggling to keep the frames, slow video or movement in games is fine. its as things speed up.
i also find pretty much every picture setting completely useless apart from standard then tuning it.
as for game mode lol, if i want to look at a stuttery colourless picture great, whats that about?
Honestly i have a 10 year old sony in the bedroom thats better than this thing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rodensony,
That's very disconcerting! Have you made sure you've got the latest firmware version v5.433? Also, make sure you're using high speed premium HDMI cables and enable enhanced format under Home-settings-external inputs-HDMI signal format and let us know the outcome.
All the best,
Tenneen9000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sorry even this dam website doesnt work, telling me my email and password is wrong, reset it 5 times still wrong, so had to delete account and create another *****
Yes latest firmware, i have no advanced setting option available like you say?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Roden,
That's strange. What are the list of options you get under external inputs-HDMI signal format? I am curious though, have you tried a factory reset? If you didn't, try it and let us know the outcome.
Cheers,
Tenneen9000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My options are
Manage inputs
BRAVIA Sync settings
Customise Tv key.
Im really trying to avoid a reset. And i will loose all my picture settings and my kodi setup.
Of course i cant back that up because writing to external drives is disabled *****
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This form sucks. A different issue everytime i log on.
Dont worry its on ebay. Pile of junk i can't stand the thing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rodensony,
That's very strange. I've checked this myself on a similar TV and I found the option for the HDMI signal format using the same steps mentioned in the Help Guide: https://helpguide.sony.net/tv/caep1/v1/en/04-09_02.html
Cheers,
The_Black_Rose
