since the last firmware,( 2017)
when I turn it on, it starts slowly or does not start. have to reboot.
Hi @yozomike and welcome to the Community
When you say reboot, do you mean powering on / off or
have you attempted a reset?
If not attempt the reset by unplugging the power cable for 2 minutes and then try
powering on again to see if that helps.
If not then you're best contacting Support.
If you're in the UK its +44 (0) 2073652810
