Dear All,
I was very surprised when my kdl-43w805c starts playing with my nerves.
I can switch on the TV, I can select channels and suddenly the TV reboots.
If I try to select the "Menu" or "Guide" this happnes again and again.
I switched off the TV which is not connected any other devices, rooters, cable networks and waiting for 10 minutes and switched on. Nothing changed, it is rebooting again.
If anyone had the same problem and the problem solved it would be great to know how I can fix this issue.
Thank you, and have nice day!
