Hello,
I have a KDL-43W756C TV that also supports wireless screen mirroring.
However if i connect my laptop or phone ( Lumia 950 continum ) the screen miroring is very laggy, and not usable.
Is there anything that i can do to fix this ?
Does anyone else has the same problem ?
Thank you very much for your time
Sebastian
Got a Sony XBR-65A8G recently and tried out the Screen Mirroring feature using my windows 10 Laptop and encountered the same lag everyone is talking about. It is weird that Chromecasting from a web browser works better than Miracast. Could it be that Sony ATVs don't have Miracast hardware/services that can handle the miracast protocol.
Also @rooobb could you expand more on the second option you suggested. What do you mean by "set a parameter for the authentication from win10" and "Enabling Simple IP control"
@naija_chinex simply enable the setting I indicated (still not sure about the translation from Italian)
Setup->network->domestic network->IP control->Simple IP control->enable
