Hi Everyone!
I have a KDL-43W755C type of Android LED TV but it has a factory problem - The TV can’t be able to update itself and i neither do that any other way. It has another problem too that i can’t turn on just if i plug out of the high voltage network before i want to turn on - The service said that it needs to change of the main controller which costs is approximately 340 USD.
Can anybody tell me how can i buy the main controller from the factory or whatever any cheeper way?
Thank You very much
look on ebay, there are some there.
AFAIK, the one from 50W75xC should also work. You will end up with different TV model but that doesn't matter.
