Hello I have a 2020 Sony 85 inch KD85XH8096BU , and on any input, TV, streaming or blu ray input the screen menu shows locked in 4:3 , when playing modern blu rays or UHD DISCS I do display in 16:9 ok but with older films that are filmed in 4:3 I would like to stretch the image to remove left and right black bars, but I’m not able to do this as the wide menu, screen menu etc are all unavailable. Anyone know how to resolve this annoying feature? I understand that distortion and picture detail on the upper part or lower part of the image maybe lost but I would like the choice all the same. Please help? Many thanks Steve.
This is normal on Sony TVs. The aspect ratio settings can't be changed on all sources. It depends on the source you're watching really.
Win_88
Do let us know how it goes.
I'm not sure exactly, I think it's something to do with the signal format. Can you adjust the ratio from the player settings?
Win_88
I have the same problem, you cannot change the aspect ratio as it is been grayed out no matter what, my TV is KD75XH7505
Yes I am suffering the same problem, my dealer changed the main board though I’m not sure why , still the same problem, Sony needs to fix this
Best regards
Steve
edited[personal details removed]
Sent from my iPad
Hey, alish- do you have the same exact issue as the original poster? Aren't you able to change the aspect ratio on any source? Also, what's the software version on your TV? Press the Help button to get it. Another thing, are you sure about the model??
Steve, what did the Sony engineer do?
Hi and yes same for us on our XH9505 - all greyed out on HDMI 1 so we cannot adjust to expert advised settings - all very annoying. Tried Ariel input and some but not all greyed out.
Hope we can get them to fix this and thanks for raising it.
Hi 2939andy, this is the normal case anyway on Sony TVs I'm afraid, the aspect ratio doesn't work on all inputs.
