i am using a USB memory stick to put on a display on a KD75XE at a funeral. The files are all in order and i want them to play in this order. The files show randomly instead of in the order on the stick.
How do i get them to play in the order on the memory stick in the slide show please.
They take too long to play. Each file takes about 12s on screen and i have 43, about 8minutes run. I need them to run through at about 6Seconds each for a 4 minute run to coincide with some music we are playing.
How do I get them to run quicker please
Kind regards
Paul
You should try a different app than the stock preinstalled one. This would be possible if you have an Android TV but I am not sure since you do not mention the TV model ....
If I'm not mistaken a 75" XE not Android TV wasn't there.
Thanks for the replies.
I have used a video application to tailor the photos to what i want and they run equally and to my time restraints, but thanks for the help
Kind regards
Paul
