Hi does anyone know how I can download a apk to this tv I've tried all sorts I just can't turn unknown sources off. Thanks
Install some file manager from playstore, like X-plore and then you can use USB stick to transfer/install apk or turn on wifi sharing inside that file manager and use browser on your computer to push that apk to the TV and then install it from X-plore.
