Hi, I purchased the KD65XD8599BU yesterday to use with my PS4 Pro - When going into the HDR settings on the console, it only shows as supporting 2k HDR - With 4k HDR not supported? Is there a setting on the TV which changes this to 4k HDR? - The TV is marketed as having 4K HDR but the PS4 PRO isn't picking it up? any help ?
Thanks, that sorted it.
