Hi all, I'm new here and I just bought myself a nice new Sony 4K tv 65" KD65X850xC on Friday and it's getting to the stage where I'm going to have to call out the shop where I got it from to sort this..
im having a bit of a senior moment with it as I can't seem to get my sky hd box and my Xbox one recognised on the hdmi sockets HDMI input 1 & 3, keeps on telling me no signal and I've done everything from restarting turning it on and off at the wall? Am I missing something here?
I have my satellite cables coming from my wall to my sky hd box then an hdmi cable from my box to the TV and my Xbox one is an hdmi from that to the tv.... This worked no problem with my old Panasonic 50" just plugged it in and that was it!
Is is anyone able to help before I pull out what hair I have left please.
thanks in advance
Turns out I needed 2 hi speed brand new HDMI cables, got new cables and all working now!
Hi there
If you are still experiencing this problem, try the following
Hopefully this works for you.
