Hi, I've just installed my KD55XH9296BU on to my wall and tried to turn it on for the first time. The white led comes on for a few seconds, the screen then comes on for a few seconds, then goes off and the LED flashes red 5 times, any idea what the issue is? The TV has literally been taken out the box today.
Hi Lstephenson,
A red blinking light usually indicates a technical hardware issue.
Please check the following help page and see if you can solve the issue:
https://services.sony.co.uk/supportmvc/en/content/triage/pos/red-blinking-after-swupd-android/10314/...
If you can't solve it I would recommend to contact you dealer.
