I am using home dlna and share films from my pc with Windows media player. I am often watching for a films in quality 1080p but the watching on films isn´t fluently. Every 20 minutes the video stops for a while not the sound. I was trying to look at the films from flash disk, but its the same problem. I don´t know what to do. Restarting the tv didnt help. The video files are without mistakes. Can you help me how to share the videos in home LAN? Thank you very much.
Hi Petak85,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Can you try Serviio instead of WMP?
Hi Petak85,
Did you try pressing Home - Settings - Storage and reset - Internal storage - Clear cached data?
Cheers,
The_Black_Rose
