So i have reset my tv tonight and upon setup finishing i have no BBC iplayer Netflix or prime video in the apps section appering at all. Netflix starts via the button the remote. Prime video starts after i enable it in the store but other apps are not available in the apps section. I have to go into youview which is not great to accces them never had to do this before, even when firmware was the same. Just after a reset has this happened. Am i answering my own question by assuming they will appear or is there a problem. I have also notes the sony select section is not available and when i lauch it from the apps option in advanced setting it is currently unavailable.
Thank god! I’ve got the same problem with my KD65XE9005. Did a system reset about 3 hours ago and all my apps have vanished and I’ve gained a few that I never had before.
