Hello
I have a KD55X9005 which on the whole I am very please about. However, i recently watched a 3D movie (Mad Max which was quite intensive) and found that there was a regular blur to the 3D as the camera shots alternated between close up and distant pictures.
I used the 3D depth adjustment to improve the situation but the blur would still occur and was very annoying.
I am using the same 3D Real Passive glasses that I got from my local Showcase cinema.
Would anyone have any idea on how I can improve this and remove the blur or was the new 3D Mad Max movie just too much for the TV to handle.
Many thanks in advance.
Hi there
TV can handle 3D - as you have adjusted the depth, the next suggestion is the glasses to be honest. The TDG-500P is less than a tenner on Amazon.
Many thanks for quick response. Order has been placed and will test with the new glasses tomorrow.
I will return with the update 🙂
