tv is only 3 weeks old.
every couple of days the screen turns totally green
only way to fix is to switch plug on and off
is the tv faulty?
thanks
Sounds like it IS faulty. Return it ASAP.
I have the KD55X8507C and not had any problem as you've described. Indeed, I've not had any of the problems most people are complaining about...
