The Video app on my Sony TV (KD55S8505C) always stretches the image to fullscreen and there seems to be no way of changing this.
Pressing the action menu reveals an option for either "Expand" or "Fit to screen" but neither of these options change anything.
Playing the video with any other app, VLC or MX Player for example, the video will play correctly, however this is not an acceptable solution as you cannot enable 3D Mode with these apps (which is just plain rediculous) so to watch a 3D file I am forced to use Sony's own Video app and suffer the stretching which makes everything look awful and out of proportion.
Is there any fix for this or is it a known issue that will be resolved in a softaware update?
Thanks,
Adam.
They've recently updated the video app on the phone/tablet so I was hoping they'd do the same for the tv version of the same app. I do hope they've specifically addressed the aspect ratio issue on the tv video app though as the update on the phone/tablet version has no mention of this.
The update has been released and in the 1.4 gb of updates Sony has done absolutely nothing about the video app aspect ratio being broken.
You are very lucky, after the update my Video app is not working at all!
I'm used to open ES File Explorer, find a file on my NAS and then select an app to open it. Well, now if I select "Video" from the list, the TV says "loading..." forever. Very nice.
I remember this behavior from very early SW versions, and in those cases for me a simple reboot was sufficient. Yesterday I have rebooted three times, but no way to make the Video app working.
I will try this evening to unplug the AC cord of the TV and see if it is a better approach...
