Still having issues. A possible solution sent from Support was applied and it performed correctly since 31/03/2021
On 27/04/2021 while watching it during the day it switched itself off. In the early hours of 28/04/2021 about 2am it switched itself on.
I am finding the constant issues an irritation.
You seem to be replying to a post but this is a new thread?
Also, if you're in touch with support already, have you tried giving them your feedback so they investigate this for you?
- JD
