So guys what type of HDMI sockets are they?
Are they HDMI 2?
Or are they 1 and then Enhanced makes them 2?
Also is there a HDMI 2a and HDMI 2b?
I know they are not HDMI 2.1 but I would just like to know which standard they are please.
All of them 2.b, setting them as enhanced you open up all the bandwidth supported by the standard (18gbps)
