Hi there,
I recently updated to Firmware v6.7140 and now when I switch the TV on from Standby it occasionally reboots. I have factory reset the TV but the problem is still there. Is this a known bug? Is there a resolution to this issue?
Thanks
Hi simonherts, you can use the contact us section on the support page.
Hello,
Is there any update to this? My TV has got to the point that I cannot use it without a reboot every so often. Surprised no one from Sony has addressed this.
Thanks
Hi sukmudha7,
I was finally able to solve this issue for my Sony (XF 9005) with some tips from the internet (not from Sony Support!) May be that will also work for your model.
Step 1:
Network+Internet> Home network setup> IP control> Set "Simple IP" to ON
Step 2:
Restart the TV then back into settings:-
Step 3:
Watching TV> External Inputs> Advanced settings> Set RS232C control to OFF.
Regards
Martin
I don't have Advanced settings as an option? Anybothercsuggestions? My KD55-AF8 reboots every time I switch on, and sometimes quite some time later.
Hi Supersupergt, you might have this in external inputs in the menu not necessarily in watching TV, that also might indicate that you don't have the latest software version.
Hello,
Spoke with Sony support who confirmed this is a known issue and the Sony engineers are working on a new firmware. In the meantime, the support person advised to switch off Brava Sync thus disabling powering on the TV from external sources.
Thanks
Hey sukmudha7, thank you for sharing this update as it might be helpful for other users.
