Hi
i just installed a new KD55-AG8 connected to a SKY HD box.
Most things work fine but the Ext Box Menu button does not produce anything.
Also the arrow buttons withheld TV guide seem to send 3 updates instead of one so channels are skipped when scrolling through.
I saw on the forum that this issue was common in 2016but should have been fixed in 2017. Is it still persisting?
cheers
Hi Gussie2769,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Hi Gus,
There are a couple of things to try/check regarding the performance in the guide:
I'm not sure what to do about the menu button on the Sky HD. Maybe Sky can shed some light on that
Win_88
