- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My TV is only outputting Stereo via the Optical cable.
I have changed all the settings but can't get 5.1 into my old Yamaha amp.
This is the same for all apps, Netflix, Disney etc.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
OK I have fixed the problem by using a HDMI ARC DAC, taking the audio from HDMI 3 and connecting the Optical cable to the DAC. I now have 5.1 from Disney+ and all the other apps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @karlflaschke
I don’t fully understand Optical but have you checked that the Digital audio out is not set to PCM, Always output in PCM. I don’t use Optical (now ancient) but mine is set to Auto 1 Output compressed audio without change.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, I've tried Auto 1, Auto 2 and PCM but they all output Srereo only.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you disabled the internal speaker, right?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, changed it to Audio System.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It could be a problem of the apps (disney for sure had problem in the past since it uses DD+ that is not supported over optical). Have you tried with a sample file via mediaplayer?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey @karlflaschke,
Thanks for the tip! hope it helps other people facing the same or similar issue.
