I have the KD49XG9005.
im in desperate need to fix the best picture settings on this TV,
as the picture on Sky Q was better on my old KDL43W809C,
a brilliant Android 2015 Full HD TV.
This should not be the case!!!!!
PLEASE HELP!!!!!
Hi @dabasto98
The best picture settings are what looks good to you. Everybody is different, it doesn’t matter what settings you use, your eyes soon get used to whatever you decide and it soon becomes the norm.
I personally use the Standard default settings with my Sky Q set to 2160p 10bit. Make sure that you have enabled the Enhanced 4K HDMI signal format in External inputs and are using HDMI 2 or 3. If you don’t subscribe to the Sky Q Experience then I suggest you set the Sky Q box to 1080i (Sky broadcast HD signal format).
