TV is hard wired with wifi turned off to BT HomeHub5.
I had occasion to look at the router logs and noticed for the last few days the lan port the TV is connected to drops every 2-3 mins. Works fine when turned on and doesn't drop the port. I've reset both the TV and the router and it's just the same.
The router log has pages and pages of:
| 10:05:23, 20 Nov. | (135746.740000) Lease for IP 192.168.2.104 renewed by host android-e (MAC ). Lease duration: 10080 min |
| 10:05:23, 20 Nov. | (135746.740000) Device connected: Hostname: android-e IP: 192.168.2.104 MAC: Lease time: 10080 min. Link rate: 100.0 Mbps |
| 10:05:23, 20 Nov. | (135746.670000) Lease requested |
| 10:05:22, 20 Nov. | (135745.650000) Wire Lan Port 3 up |
| 10:05:18, 20 Nov. | (135742.170000) Wire Lan Port 3 down |
| 10:05:17, 20 Nov. | (135741.400000) Device disconnected: Hostname: android-e IP: 192.168.2.104 MAC: |
| 10:02:29, 20 Nov. | (135573.410000) Wire Lan Port 3 up |
| 10:02:29, 20 Nov. | (135572.650000) Lease for IP 192.168.2.104 renewed by host android-e (MAC ). Lease duration: 10080 min |
| 10:02:29, 20 Nov. | (135572.650000) Device connected: Hostname: android-e IP: 192.168.2.104 MAC: Lease time: 10080 min. Link rate: 100.0 Mbps |
| 10:02:28, 20 Nov. | (135572.570000) Lease requested |
| 10:02:23, 20 Nov. | (135567.220000) Wire Lan Port 3 down |
