Hi. I’ve recently bought a Bravia tv and am having a few issues when connecting to my standard PS4.
Everytime I get a trophy message the info banner appears at the top of the screen. I have trawled the forum and can see a fix is possible via the channel setup and then turning off the banner but as I am not using the digital channels this is not an option for me.
Apologies if this has been solved but I cannot seem to find a solution that works for me.
@Berty_D wrote:Hi. I’ve recently bought a Bravia tv and am having a few issues when connecting to my standard PS4.
Hi @Berty_D I haven’t seen any solutions for this problem on Linux TVs. The work-a-round is for Android TVs only. You may get some suggestions from the Linus TVs community. Setting your audio to PCM or Normal helps as the Info Bar is appearing when the audio format changes. However that will degrade your audio experience.
