Specifications says 10bit but when connected to sky Q it can only see 8bit do i need to enable it.
If so how.
Thanks Geoffrey-B
@geoffrey-b wrote:Specifications says 10bit but when connected to sky Q it can only see 8bit do i need to enable it.
If so how.
Thanks Geoffrey-B
Hi @geoffrey-b
It is a true 10 bit panel https://www.displayspecifications.com/en/model/50e1ad8
Note you need to turn on Enhanced format Home -> Settings-> External inputs -> HDMI signal format. Probably just HDMI 2 & 3. It will tell you on the Enhanced format description.
Sorry only just seen you are using Sky Q (like me). Yes Enhanced format and use HDMI 2 assuming you are using HDMI 3 (ARC) to connect to a sound system.
If so how.
Thanks Geoffrey-B
Hi @geoffrey-b
Thankyou very much for your help
