TV auto updated yesterday and the remote no longer works, with the exception of volume buttons, power button and selection buttons.
All other buttons not working at all. TV is receiving the IR signal (the light on the front dims a little in the normal way).
Home button on the app remote isn't working either.
What can I do? Have powered off and on several times.
Try restarting Android TV by holding down the Power button on the remote control.
Manolo
Have done, I get the update message but doesn't solve the problem.
Try this, but this procedure may not work if your TV has been upgraded to Android TV 8.0 Oreo.
Follow these steps to perform a force Factory data reset.
NOTE: When facing the back of your TV, the buttons are on the right.
The (-) button is directly below the Power button on the back of your TV.
Manolo
Manolo. Good information, I have printed for possible future needs...Appreaciated.
But, I'm sorry I did not understand if you've solved or not...
Manolo
The factory reset solved the issue, the remote now functions. It rebooted in version 8.0 which I didn't expect but all works. Thanks.
