Hi, can anyone tell me the width of the stand on Kd49x8005cbu? Its especially the distance between the rear feet I'm interested in. It needs to sit on a canton DM50 soundbase. Thanks.
Hi there
I cant find the dimentions either, i believe you require the dimensions of the stand below. Do you still need this, as ill ask Sony if you do.
Ended up buying a Philips 50PUT6400. Not the perfect solution by any means but should do the job.
Thanks.
