Intermittent problem, but it's driving me nuts. Maybe three times out of five, when I access either the BBC or ITV apps, I can navigate perfectly well to the desired programme. But when I try to play it, the file simply won't load - I get a message saying, basically, there is a temporary problem with your video, please try again later.
It is NOT a connection issue - I have a very fast optical fibre connection, and the TV is sited right next to the wifi router.
Sometimes, but not always, disconnecting from the mains and waiting a couple of minutes sorts it. But sometimes not. Powering down on the remote does nothing to help.
I guess it must be some kind of software issue. Any suggestions?
Hi timinlondon,
Welcome to the community.
I'll just see if I can find any help regarding this. In the meantime though, maybe another community member might have some ideas.
Thanks,
Pascale
Hi timinlondon
Have you tried clearing the cached data?
Settings - Storage and reset - Internal storage - Cache - Clear
Afterwards, switch the TV off at the mains for at least a minute
It's always a good idea to update the TV as well: https://www.sony.co.uk/electronics/support/lcd-tvs-android-xg80xx_x80xxg_xg81xx-series/kd-43xg8196/d...
Win_88
