Have just done basic set up not sure if my talk talk you view box will work with this tv to use for recording and if does do I need to set up the IR Blaster ?
Hi Jackie,
I'm not sure but I'll try to find out for you. Someone else in the community may have an idea in the meantime though.
Thanks,
Pascale
Hi Jackie,
If your box supports recording then it will be possible to record content with it while the antenna is connected to it directly either way, and depending on what your box supports, you will either be able to use the IR Blaster or enable control for HDMI to use the TV remote to control the box as well.
Win_88
