i just bought this TV last week and it has Android TV v5.1.1
it says there are no updates available.
someone else who has a KD43X8305BU says there's is running Andoird TV v6.x
are these different models?
mine has a C in the model number, his doesn't.
"i'm looking for an excuse to return it as i thought it was a 2016 model.
as there are techincal difference i should be able to return it due to false advertising."
This is "complicated"... And I think that @Anonymous can explain "why or why not" better of me and my poor english...
Manolo
"KD43XD8305BU
KD43XD8088BU
KD43XD8077SU
what are the differenence?"
Differences are always Motionflow (XR 800 / XR 400, 900,1000) and colors (Silver or Black).
Manolo
yes but how are you supposed to tell?
if 8305 better than 8088? and is 8088 better than 8077?
what does the BU and SU denote? one would get that BU is black and SU is silver?
yes i'm sure
"yes i'm sure"
I don't think... At links: XD8077-88 and XD8305...
Manolo
What?
Verify the models at your links... Aren't all XD83...
Manolo
I didn't say they were.
I said I could see 8305, 8088 and 8077 currently listed.
And those are the links I have provided
So sorry, my fault... You have wrote correctly: KD43XD8305BU, KD43XD8088BU, KD43XD8077SU.
I have confused XD8077 and XD8088 with XD8377 and XD8388, these (last two) don't exist...
I'm hungry... -)
Manolo
