I want to connect my windows PC with 4k 120Hz capable Video Card (RTX 3060 T)) to my new XH90 via a HDMI 2.1 certified cable. When I switch HDMI input in my TV to HDMI 4 to enhanced input type - the signal disappears. In my PC windows does not recognize my TV as 120 Hz capable at 4k resolution. How can I make my PC output 4k 120 Hz function on my TV? The TV did get the latest firmware update yesterday after I bought it. |
The latest v6.0414 definitely supports 120hz 4K, have you tested another device? I would double-check that this card supports actual 120hz at 4K too.
What about the cables? If you're using a high speed 4K compatible ones then try a factory reset on the TV then: https://helpguide.sony.net/tv/haep2/v1/en/08-01_03.html?hl=factory.
