x
KD-65XF8577 green screen vertical bars big noise
profile.country.RO.title
CDD1000
New
Sometimes (frequency 1-2 times / week) my KD-65XF8577 turns to a green (ish) screen with vertical bars and generates a very intense noise. It would not revert to normal. The noise is so intense that I must turn the TV off. The TV would not start again unless I unplug and leave it unplugged for more than 10 minutes. I have asked the service people to check it out but they couldn't find anything wrong with the equipment. Any idea on what's going on?
Tags (1)
1 REPLY 1
Anonymous
Not applicable
Hi there,
Have you tried a factory reset?
If that doesn't work I would contact Sony support again.
Let us know how you get on.
Best wishes,
M
