I can't watch old BluRay movies from USB stick. Movie file .m2ts video codec "SMPTE VC-1" 1920x1080. This movies have 0 fps and only audio working. Why Sony Bravia Android TV don't support codec SMPTE VC-1? I see lot of people have same problem. Can someone update software codecs?
That’s at home. How about when you go shopping, how do you do it then?
Throwing anchor thru the car window.
OK. Now is offtop. Let's talk about solution.
If you would only answer the question sensibly, you would find that it is the solution 😛
