I am considering a kd65xd9305 but I am concerned around the light blocking issue described in this review :- http://www.techradar.com/reviews/audio-visual/televisions/sony-bravia-kd-65xd9305-4k-hdr-tv-1320298/...
Has anyone experienced this problem? How bad is it?
Is it likely to be fixed by a firmware upgrade?
Thanks in advance
Hi there
My advice is to go an view the TV in a Sony Store (or JL/Currys). Just remember that the reviews generally test the tvs to thier limits and quite often in conditions not normal in ones lounge room.
Having said that, ive not heard of people complain about light blocking.
Heres another review (55" version):
https://www.avforums.com/review/sony-kd-55xd9305-ultra-hd-4k-hdr-tv-review.12266
