Don't think it's your tv. Google "HDR problems with RDR2" seems the game has an issue. Regards
Also are you using Game Mode?
Yes game mode
I tried many modes but not showing picture quality as game mode, what do you think is lack from theTV ?
Game mode decreases input lag response time only but doesn’t increase picture quality especially motion as no motionflow enabled. Also RDR2 is only 30 fps and does have blurring issues when playing in 4k HDR confirmed. Try a 60 fps game such as forza horizon 4.
Thanks for your reply, what’s the frame rate for my sony TV and do you think the issue only from RDR2?
That’s where it get a bit technical I believe your tv runs 120hz not the same as frame rate and Xbox or PlayStation runs at 60hz. But the lower the frame rate the worse the image when in motion. Have a read at RDR2 bug problems , blurry images and bad textures also. Good luck
That’s so bad for a long waited game, Rock star should provide updates to fix this issue. Thanks again for your response
Try turning off HDR on your Xbox then run the game you will see. As I am aware this only happens when HDR is enabled. RDR2 is not true HDR either it’s upscaled from an SDR base image
