- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD-55XG8196
KD-55XG8196 software version PKG6.6545.0255EUA
Any help really appreciated here. My Bravia won’t connect to the internet. I need to try a software update. I’ve downloaded updates onto a usb. When I plug the usb into the tv it gives me options to open with album, music, video or register for recording. How do I download the updates from a usb?
tv will connect to a hotspot but when I do a search for updates it says it’s up to date but I know it’s not.
thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The new and latest Firmware is here:
If the TV wait a Video or Music File when you connect the USB is because you hasn't create correctly the USB Memory for Update.
Read Better the instruction at link...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your reply. After 4 attempts the Tv is updated now but it’s dropping the WiFi connection every few seconds so I have another problem to fix 😏
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
After an update Sony suggest a Factory Reset... So...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yeah that made no difference unfortunately.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok, and a simply Router's reboot?
Are the Bands 2,4 GHz and 5 GHz togeher?
If yes, can you divide?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
We did the router reboot. I presumed the bands were separate because I have the option to join either one. Is that right? It won’t work with either of them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try to switch OFF and ON again the Wi-Fi on TV...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your help yesterday.
after rebooting everything again today It will now connect via Lan cable but WiFi is still not working. I am done with it for the weekend 😏
