My 2 month old TV will not turn on. There is a blue light at the bottom. help me out
yes i didt work
Try factory reset. Unplug tv for 1 minute, then plug in tv. Press up arrow and hold, then tap power button on tv. If this works you should see reset option appear. Good luck
from what iv'e read the blue light may indicate something to do with WPS connection on wifi. Maybe turn of your wifi before starting up tv if it's connected this way to the internet.
