Hi. I am looking for a remote compatible with this TV with mic so i can use the google asistant as the original doesn't have a mic built in the remote, Is there one that i could buy that is compatible?
Thanks
Thank you for your reply.
Does this definitely work? is it just as simple as pairing once i purchase if so how easy is it to pair?
Check this thread:
I think it will definitely work.
