on my new KD55 X9505G the wifi performance is very poor, often dropping out and more often low quality, even though my wifi is operating fine with other devices,
I have restarted several times and turned off the other devices but the issue continues
anyone have the same?
Hi Bob,
Can you let me know if you are receiving any error codes on the screen when this occurs?
Best wishes,
Sean Mc
Hi there,
have "exactly" THE same problem with my new KD-49XG9005 android tv
Sony support are useless ( keep blaming my IP service provider or router)
but perfect on wired LAN connection- from same router !
They know they have a problem- but scared to admit it !
My son with 24 yrs computer experience ( Network analyst) says definetly
tv problem - but says other makes with buit in Wi-fi , have problems !
there are no specific error messages except a pop up stating wifi not connected, but just to remind you the wifi works fine with other devices at the same time.
