Hi, Is It Possible To Remove Apps That Are Pre Installed? I Dont Use Them Like Deezer, Disney+, Chrunchyroll, Netflix, Prime Video, You Tube, Kids, Music, Viki, Spotify To Name A Few..Ive Added USB Storage Which Is Great But The Internal Storage Has Used 3.6GB And Left Me With 857MB..
I Have Uninstalled Various Apps That Can Be Uninstalled And Disabled The Others, I Cleared Data And Uninstalled Updates Prior To Uninstalling/Disabling. The Issue Is That The Apps Are Constantly Reappearing. Any Help Appreciated. Thanks
@KyaMarley75, pre-installed apps cannot be removed. Use the USB as an external storage, there's no other way.
