Does anyone else have an issue with the TV stop responding to the remote occasionally? It starts working again after about 30 seconds and the picture is unaffected. Seems to be mainly when I'm using the remote a lot ie tweaking picture settings etc
Hi there
Apparently you are not alone on this issue. Sony is aware of this and as far as im led to believe, will be resolved in an up coming future firmware update.
Thanks for the reply. Are there any other discussions on here about the issue? I couldn't find anything but probably misses a load!
Im not sure if there is a specific thread for this, but im sure ive seen it mentioned in the main Android thread:
https://community.sony.co.uk/t5/televisions/2015-bravia-android-tv-issues/td-p/1949079
But it is also mentioned on the Irish Support site:
http://www.sony.ie/support/en/content/cnt-hn/prd-tvhc/android-tv-features-update
