Has anybody had the the issue with the tv keeps coming up in top right hand corner WiFi not connected with a ! But it is connected when checking connection
Please check if the software of your TV is up-to-date.
This issue should be fixed with the latest version.
If not, you might want to check the clock setting of the TV.
Cheers been trying to find in settings how do I know if it’s updated or upto date any help on that one please also do you know if the screen can open up to give full picture in movies ?
