My 2018 Sony KD55 AF8 has just today, when turned on,by the remote, goes into normal screen mode showing the normal available Apps etc.
When I try to select, by the remote, eg UTube or Prime,it turns off, then starts up itself ?
I have unplugged every attachment, firestick BT box etc then switched off from all power and waited 10 mins, but it goes through the above again! I can't get to settings as its just goes through the shutdown process and the remote has no control over this?
Has anyone any other solutions or is it a hardware problem 🤔
Appreciate any help offered
Jim
Try testing your remote using this guide, maybe some button is stuck and causing this (most likely power button, but could be another one or just the remote itself).
Hope this helps!
- JD
Thanks, but had checked the remote first, I actually had changed batteries a few weeks earlier, but changed them again, just in case.
Hi @jimsouthstand,
It does seem like a glitch. Well, glad it's gone now, but keeping the TV up to date is never a bad idea (especially to avoid glitches like those).
Hope this helps!
- JD
Thks Joe, yes it has been working as normal since! I have the auto update switched on but also check manually regularly!
Thks again
Jim
Glad to hear it ^^
Be sure to mark the solution (if it's one of the posts) or post in detail then mark it so others can use the info as well!
- JD
