Hi Guys,
For some reason when I press the Input button on the remote to switch between my HDMI inputs I get six options, when I only have three boxes connected.
All three show up twice but with different descriptions.
I assume it's due to me turning on Bravia Sync, so my Soundbar works automatically, but I don't understand why it should change the input list.
Any ideas?
Hi @Elodin
Unfortunately, the option to turn off Bravia Sync Control is not available on my TV because I have a Soundbar connected via HDMI (ARC).
This might be a bit silly but have you tried to go to Manage inputs in External inputs and delete the duplicate ones?
Hi @Anonymous
Sorry that doesn't work.
I've been there but the "extra" Inputs don't appear in the Inputs section, only the "Real" ones.
I did try the opposite way round and used the hide option on one of the "real" ones, hoping the "extra" one might still show, but that doesn't work either, both disappear when you hide one.
But thanks for offering the suggestion.
If it won't disappear with all that, I think a factory reset will be the way to go 😞
